RENDRERING: Elementary Questions
  • How do I force Maya (version 3) to render AVI's with 25fps (frame rate/PAL) and not NTSC (29.7??).
  • Is it possible to merge an audio file with the AVI file during rendering? (If so, how. i want to avoid post-processing)
  • Is there a flag with which I can force Maya to ignore ALL/some textures during rendering??
Thanks
the answer is in the faq but here goes since im boored.
You dont maya doesent put any fps rate, its windows that asumes ntsc rate. And its not compressed, period.
No.
this is pretty much a philosophy issue on the may dev part since there are progs that do theese things so much better its not iplmeneted in maya. Besides alosta ll studios do some kind of comp in wich case its same anyway.
not, realy but you could easily do asrit that does this (or indeed make a direct connection to sme atribute that does tha sema thing).
