Dear everybody,
I'm quite a new user of Mac OS X and used Shake for about 2 years.
I have a problem that occur when Shake 4 is rendering.
It sometimes work properly but most of the time, the rendering (not the complete Software) crashs at any moment during the rendering.. I still have access to Shake to save my script but the render window is freezing.
I didn't have that problems a few days before. And it seems that it's getting worse every day.
It's quite boring when I start a batch render during the night and omly have 50 of my 1000 frames rendered.
Do somebody have a suggestion ?
The graphic card, software problem, OSX problem... I'm a bit lost on a Mac.
I'm using a 30" inch monitor that doesn't seem to be properly managed by the graphic card (slight artifacts when using RotoShapes), and resising a rendering windows increase the risk of a rendering crash.
Thanks in advance.
Thim
The Mac System Profile :
Hardware Overview:
Machine Name: Power Mac G5 Quad
Machine Model: PowerMac11,2
CPU Type: PowerPC G5 (1.1)
Number Of CPUs: 4
CPU Speed: 2.5 GHz
L2 Cache (per CPU): 1 MB
Memory: 3.5 GB
Bus Speed: 1.25 GHz
Boot ROM Version: 5.2.7f1
System Software Overview:
System Version: Mac OS X 10.4.5 (8H14)
Kernel Version: Darwin 8.5.0
Boot Volume: Macintosh HD
Graphics/Displays:
NVIDIA GeForce 6600:
Chipset Model: GeForce 6600
Type: Display
Bus: PCI
Slot: SLOT-1
VRAM (Total): 256 MB
Vendor: nVIDIA (0x10de)
Device ID: 0x0141
Revision ID: 0x00a4
ROM Revision: 2149
Displays:
Cinema HD:
Display Type: LCD
Resolution: 2560 x 1600
Depth: 32-bit Color
Core Image: Supported
Main Display: Yes
Mirror: Off
Online: Yes
Quartz Extreme: Supported
Display:
Status: No display connected
Memory:
DIMM0/J6700:
Type: DDR2 SDRAM
Speed: PC2-4200U-444
Status: OK
DIMM1/J6800:
Type: DDR2 SDRAM
Status: OK
DIMM2/J6900:
Type: DDR2 SDRAM
Status: OK
DIMM3/J7000:
Type: DDR2 SDRAM
Status: OK
DIMM4/J7100:
Type: DDR2 SDRAM
Status: OK
DIMM5/J7200:
Type: DDR2 SDRAM
Status: OK
DIMM6/J7300:
Type: DDR2 SDRAM
Status: OK
DIMM7/J7400:
Type: DDR2 SDRAM
Status: OK
PCI Cards:
GeForce 6600:
Type: display
Bus: PCI
Slot: SLOT-1
Vendor ID: 0x10de
Device ID: 0x0141
Subsystem Vendor ID: 0x10de
Subsystem ID: 0x0010
ROM Revision: 2149
Revision ID: 0x00a4
bcom5714:
Type: network
Bus: PCI
Slot: GIGE
Vendor ID: 0x14e4
Device ID: 0x166a
Subsystem Vendor ID: 0x106b
Subsystem ID: 0x0085
Revision ID: 0x0003
bcom5714:
Type: network
Bus: PCI
Slot: GIGE
Vendor ID: 0x14e4
Device ID: 0x166a
Revision ID: 0x0003
