Hi,
I made some Vue objects in Maya using Vue xStream Plug-in.If i render the single frame or batch reander in Maya its fine.
If i render same file with "Smedge". Render not happening.It saying Error like."Error: line 0: hyperShade command not supported in batch mode" in log.txt file.What is this error, And how to fix this problem ?
Thanks.
  • created
    Jul '14
  • last reply
    Jan '15
  • 1
    reply
  • 2.0k
    views
  • 1
    user
6 months later
If you see an error like this in Smedge that does not affect rendering, you can tell Smedge to ignore the error:
  1. Select your job and use the Job > Edit Job command
  2. In the "Advanced Info" tab, go to the "Error ignore strings" and add the text "hyperShade command" there.
  3. Press Update and Close
  4. Use Job > Reset Job Failure Counts to get the job running again.
