Reset all prefs
Simple combustion question:
is there a way to reset all of combustion's preferences?
brushes/palettes/views/workspave/ e-v-e-r-y-t-h-i-n-g
if not, how can it be done serperatly
Although there's a reset button for each pane of the prefs panel, probably the best way to go back to the default settings for everything is to delete the .ini files in the root of the combustion folder. There can be up to 3 of them - host.ini, paint.ini, and effect.ini. The next time you launch combustion will re-build the prefs using default settings.
Brushes, swatches, and mixers are saved in their own folders, however. If you want to go back to the factory presets on those, you'll have to get them from the CD.
