Hi everyone, this is my first post on this forum. I just joined up about 2 minutes ago and as you'll shortly see I have essentially no experience with 3ds max.
I've made a few paths in Photoshop and exported them to Illustrator format to be brought into 3DSMax and turned into a 3d model. I've imported them in and I have enough basic knowledge to extrude a path using the extrude modifier. What I want to know is if there is some way I can delete part of the model or mesh or NURBS or whatever lol (see, noob) using another path (I have one ready) or otherwise. The image below might give you a better idea. Image 1 is the base path extruded. Image 2 is my desired result (crudely photoshopped). Basically I want that crest surface to be an outline.
Is this possible?
Thanks in advance,
Chris
