I have a PAL telecine with 2:2:2:2:2:2:2:2:2:2:2:2:3 pulldown clip, that I need to cut down and then convert to NTSC.
I couldn't find a tool to remove the pulldown.
This is an almost 10 year old transfer. It's a Musical. Back then they did NOT WANT the 4% speed-up of a 24@25 telecine.
I have to make a (NTSC-) trailer from it. This is the only material available.
Is there an easy way? Divide the fields, throw out every 13th field and recombine fields? Scripting or expressions?
To clarify: I want to get back to the 24fps original. Then edit in 24fps. Then conform to 23.98fps. Then resize/add pulldown to get NTSC version.
Thanks for help,
gizmosito
