I'm looking for a tip on how to make a surface arround a curve. I would like to make a spiral, and figured a curve would be nice for that, that has a surface wrapped arround it. Like a cable for an example. Revolve just doesn't seem to be it!
Hi, thanks for the tip. I tried that but it's not really what I want. Id like to make a surface around a curve. So I can easilly animate it by changing the curves shape.
Hmm. mayby I could use a skelleton with som IK for the stalk of a flower (to make it Dance or what ever).
Well yes... or then just extrude but thats probably simpler.
Another nifty but more complex way is to revolve straight atach to a motion pathdelete the other key and use deform along curve with local option set to 2 2 2 or 3 3 3... now it folloews the curve provided that the laticce has enough resolution and the curve and the revolve can now be animated. (this might cause some probems with curves that are strainght up so use a gurve on surface instead with the normal option on if this cause s probs!).
