Rig problem - Adding Blendshapes to existing node in Maya 2011 Mac OSX
Working on a project, while I figured I needed to add 2 more shapes for each side of the face, for my blendshape driven face rig.
I got the shapes banged out, imported them into the main rig scene.
Note that nothing is referenced at this stage, and that it was a perfectly fine rig. Animated a few shots with the rig too. I have a reference pipeline, btw.
Imported the Blendshapes (BS). renamed them according to the scene, and how they were supposed to appear in the bs node. selected them in order, then the main mesh, and Edit Deformers>Blendshape>Add , specified the node, and Apply, and I get this error:
// Error: Problems occurred with dependency graph setup. //
I get the same error, when I also changed the deformation order, and brought the bs node above the skin cluster. Tried looking around for a solution - Nothing.
Can you help me with a workaround, or a fix for this ?
Much appreciated !
Hmm yes see selecting things in the scene doesnt actually point maya to the right node in all cicumstances. Try doingthis all in script and refeer to tha actual node names instead of trying to autodeduce form the gui.*
*its very commen for may naive implementations of networks to assume you can allways sort out node form selection, this si NOT THE CASE
Following your advice,  I used MEL.
blendShape -e -tc 0 -t Kat_geo 58 Kat_L_upEye_up 1 Face;
(58 being the 58th target shape to be added to the existing Bs node. The Target Index.)
// Error: Object will not allow alias ‘Kat_L_upEye_up’ to be set. Possibly because an attribute of that name already exists. //
I wonder if it might have anything do with set-driven keys from the GUI to the mesh ? Also, in 2011,  i had issues plugging the blendShape node into the SetDriven key window, and so worked around that with a null of the same attributes and connected them to their respective target shapes on the bs node.
I tried to extensively elaborate on the problem, and I hope I didn’t miss out on much.
Much Appreciated.
hey
try changing the name of the old attribute.
it also easy to “bake out” all the blendshapes and build a new blendshape node.
chris
