Well then are they REALLY expressions or do you use mel inside your expressions (you should not, because using gettar and setattr, xform etc circumnavigate the wohole operating mechanism of the network).
See expression language is NOT equal o mel.
So if your going t use expressions then your really going to need to know how maya nodes are supposed to operate, and all problems you get is really up to you knowing its a bad idea.
