Rigging With Dynamics Updated Realtime Viewport
Hello everyone there, first post here!
I’m a rigger and after following some DVD trainning i feel comfortable in that field.
However there is a little thing that I would like to know how to do and I never was able to know where to look for. Don’t even know a dvd that will explain it.
it a follow through action (antenna, tie…) that are driven by what seems to be dynamics but that are actually update in realtime in the viewport. So I would like to know how to setup that kind of thing.
On exemple of that kind of motion is seen in the making of le Building.
http://www.le-building.com/makingof\_staphylas.html
With the motocycle or the passengers in the Bus you can see some element moving with a delay but the timeline is not moving, which mean that it’s updated directly in the viewport.
So if anyone has a clue on how to do that, I will really appreciate that!
Mathias
do you want it to update or do you want it to update so it shows what the effect will be wen it really keyed (and thets not what that rig does, it is in fact VERY hard to do)
Thank you for your reply Joojaa
what does exactly do this rig?
but yes if I can see the dynamics being updated realtime in the viewport to show me how it would be animated, that would be the best!
thank you again!
Mathias
QUOTE(saihtam @ 01/31/08, 05:18 PM) [snapback]280403[/snapback]
Ok tahts hard because it requires you to key in certain style. The rig yu showed just uses the cached previous value to suimulate stuff (you can see it because he moves things around). It relevively easy to do however its in practicality not usefull since moving mouse around does not correspond to when happens once the thing plays. Or alternatively just add dynamics solvers to the objects.
However its possible to querry the keyed value, it looks far less impressive on screen tough but gives you MUCH better feedback of what will be, but reuires you to use auto keyframing. Its very uneefective for maya bit can be done.
im a bit busy so youll have to waiit for a simple example.
thanks so much for taking the time to reply to me Joojaa.
A sample will be amazing but there is no rush, it’s just to increase my knowledge!
I’m also doing some research about the cache
So it seems in fact that it’s possible with expression. But I don’t really know how to do it!
I need to have a variable like a $NewTime++ each time that there is a move of a particular object.
so I need to have something like that in the expresion
if (object is moving) {$NewTime++}
what I was thinking is doing something like
if (NewPosition != OldPosition) {$NewTime++}
but I don’t know how to keep the old position and when to do it!
so If anyone has an idea…
thank you!
Mathias
