Hi everybody, I have a small problem with a rigging system I’m working on. Whenever the character rotates on the Y and a body control moves, the material in certain areas seems to crush itself, only in certain positions. For example, if the arm rotates to 3 degrees its okay, 1 degree more and the material crushes itself on the wrist area, another degree and its back to its normal position. It’s like flickering. I checked the flexor I used for the rigid skinning and when the “crushing” occurs, some of the lattice points (the loop in the middle of the flexor) interchange positions (the bottom ones move to the position of the upper points and viceversa), thus affecting the model.
Has anyone faced something like this? At first I thought the expression that controlled the wrist was wrong, but this occurs in several parts of the body, including the ankles, which have no expressions. Something is making the points in the center of the lattice to move, but only when the character rotates and it’s no longer on it’s initial position.
Does anyone have any advise on this?
Mayas rotate is full of bugs and the rotation axis sometimes mess up, I also find problems with wrists a lot because of this
This has nothing to do with rotate havinga bug or indeed that rotate has bugs. euler rotations are just problematic in mathematical terms tell maya use quats.
But rather how you have rigged this. For exampe constraining would cause this as would not having enough rotational segments to use the rotation ON so once you start extreme rotations say 90 degrees you need to interpolate the rsult so you need a halfway rotation in the efflector since a box with other end twisted more than 60degrees is collapsed because it turns on itself. As the rig can not interpolate the data in between in other ways.
Describe the rig better.
QUOTE
Name one bug. Anyway ive been using maya for years and havent found any bugs in mayas rotate. Maybe you just dont understand how eulers work. (this reprsesentsa big problem wich acnt actually be solved with teh current mathematics totally, since no one can visualize quat values and thus cant edit and ease right a quat data and eulers dont interpolate well if you dont align their rotation order right, this itself is not maya problem BUT a technology problem. We just dont have the perfect math for this)
Anyway this si a sort of a novice type problem. Once you start thinking what exactly you told the computer to do it becomes evident. (computers are big on doing exactly what you told them not what you TOUGHT you told them)
PS: this said theres alight interpretation limitation in lattice when you drive it with clusters and rotate 360 degrees but teh tarsfroms still sum up causeing any inetrpolant to contiousy become wilder and wilder, maybe whats whet you guys are seeing?
