Role of GPU in scene rendering?
Sorry to seem ignorant folks (I am) but can any one tell me what the video card does for rendering? Im not so concerned with how things look/move on the monitor but with how long it takes to render a particular scene.
Hmmmmmm.
The video card has nothing to do with rendering the scene, it is for monitor display only. Now if you are playing your animation in your software it makes a difference, especially if you are using a newer card that supports hardware shaders, that is if you are using hardware shaders (mainly for game developers though)
-CS
Just a note… many of Maya’s particles needs to be hardware rendered… that is… your graphic card renders them.
Thanks everyone for the reply…
I guess I will just get a GF4 not a QUADRO4…
(incedentally the Q4 was supposed to be available by now according to ____?)
Certain constraints limit me to an LCD monitor anyhoo so stuff will look crappy.
Thanks -------------------Blar
This might be a kind of stupid question, but if not the video card, then what is it that controls rendering time? Or maybe I should say, what affects render time. I want to upgrade my computer a little…it has 512 Mb RAM and I want to add an additional 512mb-1ghz of RAM…will I really notice the difference? A. Going from 512 to 1g or
B. Going from 512 to 1.5 g? Will adding RAM speed up my render time any? Sorry for all the elementary questions but you guys are always so helpful!!
Thanks as always
Tulane
Please people pick-points with me if I’m wrong (I guess you will anyway)…but If your CPU’s’ working at full tilt rendering a BIG scene & you’ve only got 1/2 Gig or RAM supporting it the system’s likely having to I/O data from your HD (like point/vector/texture info etc.)…adding RAM will remove this page file access-time from the overall render time equation, so speeds the whole process.
It’s generally the case of ‘the more RAM the better’ but you can have overkill (like the solid-state RAM drives available,…Oh you would, given half a chance & a bank balance to match
…one way to gauge the peformance is to watch CPU, RAM & page-file use with something like the Norton Utilities suite.
Ideally (financially at least) your system should only ever use VM(page-file) with VERY heavy scenes,…meaning that you’ve just enough RAM to cope with normal useage without loads of surplus hanging around waiting for a job.
1Gig is nice but 1.5 is sweeter,…especially when matched in with the CPU & HD set-up nicely.
Scene rendering is pretty much data moving between the CPU(s), RAM, and hard-drive…and obviously bus speed, which is how it gets to and from all of these. The graphics card is completely ignored…which is why most renderfarms have crappy cards, and few or no monitor at all.
The card accelerates Open GL displays, which is used by the modeling viewports. It’s used in HyperGraph, graph editor and even the Shake interface as well, so it isn’t just 3D.
Rendering is important of course, but do not underestimate the imporatance of the vid card…considering that most relatively complex scenes will require 90% interface time (building the scene), and 10% rendering time (just wild and general guesses to make the point) most people consider the card the heart of the workstation and trade off a slower CPU for a better card if necessary. This probably has a lot to do with the fact that you don’t actually sit in front of the machine while your rendering…for long periods of time anyway.
the TYPE of ram you have is also important.. since rendering is a process which stresses your data IO bus.. DDR ram will be faster than your normal SDRAM..
Thanks for everyone’s replies…
What about RDRAM…what’s the word on that?
A little more info…I’m running P4 1.8 40G HD 512 RDRAM with a GeForce 3 Ti 200 under Win XP…I know that someone said the Graphics card is for the viewport not the render (in a nutshell!!!) My problem is my renders are taking up to 20 mins a frame (I have some paint FX in the scene) and I really need to speed that up somehow. Modeling etc. in the viewport is working well, I just want faster renders!!!
Thanks again,
Tulane
Learnging how to optimize your scene for shorter render times is just as important as optimizing the hardware. So for fastest renders, be sure to do both.
For scene optimization, you can use the render diagnoistics for some clues, but best is to first know what kinds of things need to be checked (read the maual).
Be aware of the optimize scene command. It’s a great thing, but know what it’s doing so you don’t delete something accidently.
Some obvious things to set as low as can be while still maintaining a good image:
Tesselation Levels (Especially SubD. Defualt 4 is usually way more then needed)
Sampling levels in the render globals(there are many, each for different things)
Depthmap shadow map size(don’t make it larger then needed) and reuse maps when you can
If ray tracing, don’t use 10 bounces if you only need 2
There is a lot more to this, most of which you can find in the manual or come up with just thinking about it. PFX has it’s own optimzations too.
On the OS end, defrag your drives often. Clear up memory and cpu resources when rendering(close the apps you don’t need open).
Render from the command line and make use of render flags(all in the manual). Close maya when rendering from command line to save ram.
As for hardware, your set up is good. If after optimizing everything you find (in the task manager) that you are using more ram then you have, then consider adding more.
Chances are doing all these things ( optimization, not adding hardware) will cut your render time down a lot, maybe even in half or better.
By the way, the manual is just an F1 (or in help menu) away. Use it!
As for your general hardware knowledge(is RDRAM cool or crap), here’s some sites to learn more and follow the news.
www.anandtech.com
www.2cpu.com
www.tomshardware.com
www.3dgpu.com
there are tons more, those are just ones I visit often.
Good luck and happy renders
~Garret
Thanks for all the info, everyone!
Tulane
Yeah thanks y’all!!!
Y’all are ok, I dont care what everyone else says;)
How 'bout this… Any of you have minimalist micro-tower set-ups to be yer good ole desktop render farm (render garden)?
----- Blar The Impaler
