I am having trouble getting 2 objects to rotate in opposite directions.
I keyed one object to rotate 360, and the other to -360 in the same Y axis. But they both ended up rotating the same direction. Any help will be appreciated.
set upa na expression:
object1.rotateZ=-1*object2.rotateZ
offcourse if the object 2 space is the other way around just delete -1 or use direct connections for sake of simpicity!
