Its basically just c++ with python as host language (thats why its hard, its made byprogrammers to programmers). I've tried to document the inner thinking here quite well so you get the idea.
import maya.OpenMaya as OpenMaya
#make a object of type MObject
obj=OpenMaya.MObject()
#make a object of type MSelectionList
selList=OpenMaya.MSelectionList()
#add something to it
#you could retrieve this form function or the user selection
selList.add("pCube1")
#fill in the MObject
selList.getDependNode(0,obj)
#check if its a transform
if (obj.hasFn(OpenMaya.MFn.kTransform)):
#then we can add it to transfrom Fn
#Fn is basically the collection of functions for given objects
xform=OpenMaya.MFnTransform(obj)
#now the api requires pointer types
x = OpenMaya.MScriptUtil().asDoublePtr()
y = OpenMaya.MScriptUtil().asDoublePtr()
z = OpenMaya.MScriptUtil().asDoublePtr()
w = OpenMaya.MScriptUtil().asDoublePtr()
#we are ready to ask the values
xform.getRotationQuaternion(x,y,z,w)
#convert them back to normal python floats
x = OpenMaya.MScriptUtil().getDouble(x)
y = OpenMaya.MScriptUtil().getDouble(y)
z = OpenMaya.MScriptUtil().getDouble(z)
w = OpenMaya.MScriptUtil().getDouble(w)
#and print it out
print ("QuatRotation is: "+str(x)+" "+str(y)+" "+str(z)+" "+str(w))
Please note asking for the values via getAttr gives you the channels wheras this gets the values fome th actual transformation matrix. As such theese are computed out and the getAttr values are allways what maya stores for users to see ans set.
