Rotation problem
K I have a line(rectangle bar) and I wanna rotate it around in a circle..The Bar is inside a seperate circle dividing it into two halfs.....when I try to rotate the bar around the circles center the rotate stretches my bar everytime it reaches a horizontal position(meaning the line gets longer when horizontal and is shorter when verticle) anyone know how to fix this problem without having to scale my object down everytime its horizontal??? or do you know why its doing this?? The pivot is directly in the center of the circle and so is the bar......
It sounds like your aspect ratio is the problem....
PErform at test to see if this is correct. Create a constrained circle in the paint module. Now rotate it around. Does it become oval instead or a perfect circle.
What you should do is right-click on the viewport and select USE ASPECT RATIO in the pop up menu and that should solve the problem...
Splice...
