QUOTE(janjacobsv @ 02/09/09, 04:44 AM) [snapback]300508[/snapback]
if i have the axis of rotation, and the angle which should get my object on the right vector how do i rotate that. which rotation order etc
Maya can do any rotation order just instruct it to use some other sequence.
http://www.euclideanspace.com/maths/geomet...Euler/index.htm
However the real problem is what order did the OTHER engine use? If the y angle is not the last one accounted for then you dont have proper axis angles so it might be a bit hard to do any import.
You dont usually call the rotation in axis angles as the one around y because its NOT its about the axis.
