RPC render with Mental in Maya (HELP... PLEASE
It wont do a batch render…
I can only get it to work when inside Maya when I render the current frame…
it
what do u mean by ‘RPC’ render…? with MR you should render outside of maya from a command prompt - this is the best format to use:
call mayarender_with_mr -file [filename]
The problem that you describe sounds like a problem that existed in earlier Beta versions of the RPC plug-in for Maya. Downloading the latest version of the plug-in should resolve this batch rendering problem.
Any time you have problems with the RPC plug-in please contact ArchVision Technical Support www.archvision.com/Support
Nathan
Hello Corsario,
The plug-in for Maya is still in the Beta phase. What version do you currently have installed. The most current version is 1040. There was an issue with batch rendering that I encountered in early versions (1020 I believe) but 1040 should work. You can download this from www.archvision.com/maya if you have not already.
As long as you are using RPC for Maya 1040 and are rendering with Mental Ray then you should be able to batch render. PLease go to www.archvision.com and create a support incident if you continue to experience difficulty.
If you do not have an account at www.archvision.com, you will need to create one. You can do so under Account—>Create New Account. Once you have an account, go to www.archvision.com login and select Support—>Support Manager to create an incident. Incidents are free and the folks at ArchVision will help you to resolve the problem.
Thanks,
Jon Anderson
859-252-3118 ext 103
