Scale tool like 3dsmax
Hello,
I have recently moved from 3dsmax to maya and I find the scale tool in Maya limited. I would like to have the options that you have in the move tool such as local normal and to scale based on screen space. This is in 3dsmax which is helpful for modelling - pushing and pulling vertexs. For example if you wish to make a bunch of vertexs planar and their not parrallel to the object's tranform or world space - you rotate camera by eye until the vertexs are almost in line then scale (squash) until they are planar.
Any ideas or mels scripts or plugins - please help
In maya you would use move tool for this. Its fater and better. (yes in maya you can use move tool to planarize supprise supprise.)
Sounds good!
but how do I planar them, I've tried it on normal, local and non of these work. It works fine in a side, front, top view but no good in perspective - which is really what I need. Anymore ideas?
hit down "w" (thats the small letter) click on to your viewport and uncheck keep facing asuming its on (you can also get to this option via doublecklicking move tool). Also check the tool to global.
Then select your vertices hit the "v" button for vertex snap and grap the manipulator gizmo along one axsis thamn snap to the point and they lll just got planarized on the plane thats normal is the arrow you selected.
For instance.
Thank you for your reply,
That works well but doesn't quite do what I want. I need to make the verts planner relative to the camera. i.e. perpendicular to it - not to the object or world axis.
Aaah I think I know wht your doing Was cofused about it for ages. (used this as a cheap vector renderer whew it still wasnt part of maya, still do to get those nurbs out as splines).
One overly simple way is to:
Parent your object to your camera and scale it down to 0 along Z it will however move your object to the cameras point so you need to repsoition it later.
Or do you perhaps need a perspective planarize?
This is the simplest way to describe one planarize of this sort, you get much better results by hooking up a few matrix ops but its not realy basic maya stuff anymore.
Anyway if your doing uv mapping instead of vector exportting of some sorts (in general its easier to use the vector renderer for that anyway) then use create uvs based on camera in the uv editor instead.
thanks again,
yep I need the perspective - I guess I should leave this as you mentioned it's going to get quite complex. A pity as this is a very handy tool in 3dsmax. If you come across any quick solutions please let me know. Essentially I just need some of the options that are under the move tool to be in the scale tool
ITs not impossible to do? what do you plan to use it for? (it makes designing a script for this easier, if someone is interested or indeed i have time to do one)
ideally I would like to have a few more options under the scale or move "options dialogue box". Or on the menu markings.
Essentitaly it's for general modeling. So a tool that would be permanetly under the move or scale tool.
It's like it's almost there - you can select the yellow square and move a vertex or object aligned with the perspective camera but once you select a single axis such as the y it moves in the local or world depending on which option is checked.
Essentially one of the axis needs to point straight out from the camera and work with the snap tools. If you need more clarity please just ask some more questions.
I appreciate your help.
Sorry the tool itself cant be extended that easily. The effect however can be done with other ways, such as invokinga a command that sets the obbjects to different spacce for a while or so.
Its easir to deform along a views axis than to planarize along one tough. And youd never notice the difference untill you inspect teh history of it all.
Idealy one would use api to make a new tool but i dont have a compiler so i cant do it...
