Scaling Characters With Skeletons
Hey this is my first time using these forums, and I am in urgent need of help! My school project is due in two days (one of which I have to leave for rendering and editing). Well my question is: How do you scale and rotate characters that have been skinned and with skeletons? Whenever I try to scale the skeleton (from selecting the root joint), it distorts the character. And when I try grouping the character and the skeleton and scaling it, the character gets bigger but the skeleton stays the same size.
Any input would be greatly appriciated! (asap perferably!)
Thanks,
Brook
Well yes your having yourself a problem here fisrt you msut understand what a double transform is.
Se you will need to group the skeleton, BUT NOT the character skin itself. Thsi is a bit tricky and in reality needs to be designed BEWFORE you do your stuff since doing it afterwards may infact be MORE work than doing the original setup fisrtplace. However you can easily g trouhg all nodes in the hirearchy and decide wich ones are in a double transormation place and move them to a skin group WICH is not uder your skeleton, or unchek the respective ojects
So in effec you will need to separate SKIN fom skeleton (dont worry itll still be part of the skin), because just scaling them both would cause the skin to scale 2 times.
