Yes,
1) If you use either Resize -or- Zoom -or- Fit for scalling (here you dont have to use scale node seperatly).... then if you apply move2D you will Get the controls in the smaller size.
2) If you use Crop, Viewport, Window - you have to first use scale node and use any of these three, then if you apply move2d you get smaller controls.
In all the above cases, all six nodes will move your scalled input to the left bottom corner. ( if you composite this manipulated image with the original image you can understand. )
pls let me know
thanks
Nishok A
