Scene View Turned Black
I'm a newbie and I've spent hours trying to figure this out. For a week now I've been unable to change the background color of my "scene view" back to the default gray. I'm not sure what key stroke I made but I somehow changed the scene backroung color to black. Everything else is working fine except for the "Black Background" It does't matter if I'm looking at perspective, front, back or side -- every view is now has a black background. Has this happened to anyone else and does anyone know how to restore it back to the normal gray??????
Unless something is broken, it's under the menu: Window>>Settings/Preferences>>Colors..., and then under the General Tab, it's 3D Views.
You probably hit alt + b this hotkey cycles the BG color from 50% grey to black to 75% grey. It's helpful when you need more contrast between your model and the BG
Hey! Great little tip with the alt+b thing! Who knew? I can't believe I haven't accidentally hit that myself.
QUOTE(XanderFX @ 08/13/06, 01:40 PM) [snapback]245015[/snapback]
Thank you ,thank you ,thank you......it worked
Ps :Thank you
Doug
