Well im not so supprised. After all theres no way you can get more precise controll than either keying it or doing an expression. I mean lets face it if the ui saves you 10 seconds every time okay. But thenagain keying this takes what 2 seconds. Doing an expression 10 secs tops for simple ones like that. And if you needed it batched then you would need a loop to import many different footages as well...
Yeah, on those lines making a script that it loads footage in batch mode to one or several file nodes at once then it might actualy be usefull.
As for editting the AE template... you se theres a big problem there, you could edit it but humm its AWs code thats owned by AW i mean its fine if you use it at work, but i wouldnt go around distributing it. And theres no way that someone would waste theirtime reverse eibgeneering it.
