I’ve been digging around for a script to do this for a while but had zero luck so far. Was hoping someone here might know how to do this.
The best I could come up with was copy/paste attributes from one object to another.
The problem is that it’s really slow for what I’m doing.
Im using this on very simple proxy rigs made up of parented geo. I need to be able to build and test these models rapidly without fiddling with real rigs. Something that can transfer attributes to all objects under it by matching names.
Example:
If I tweaked the geo for “Base1” I want to be able to match all the objects within “Base2” and get the same overall pose. Without doing it one object at a time
Hi
Since you have the script to do manually putting them into a “For Loop” will finish the job real quick.
Try this, here you have to give the attribute to connect in the fields:
I tried out the script you linked. I’m afraid I couldn’t get it to work for rotations. Don’t think I’m using it correctly. My scripting ability is basically restricted to copy/pasting sadly I found my copy attribute script in a forum.
How do I connect say the rotation values using your script?
Hi
In the text box give “.rotate” and “.rotate” again.
Select all the source obj and press “Get”
Select target obj and press “Get”
Then press connect button.
Regards
Prem
