scripted ops
hi
since scripted operaters's code runs every frame it initialize variables every time. can we declare global variables? How?
defining subroutine "sub( ) end sub "also causes syntax error
some body pls explain
Thanks
If you want global variables in your vbscript operator then define them in the auxilary code section ( second pane ) for example
Sub Update(In_UpdateContext,out)
logmessage MyGlobalVariable
End Sub
Dim MyGlobalVariable : MyGlobalVariable = "Hello"
Just a side note:
A Scripted Operator doesnt run every frame.
It is triggered when one of its input has changed.
One way of triggering a Scripted Operator every frame is to create a variable, and set an expression with 'Fc', for instance. ( or 'T', etc.. ).
