Longtime Maya user just getting my feet wet with xsi. The first bit of frustration I’ve run into workflow wise is that there seems to be no mode where you both select and translate components. In other words, I have to first enter a selection mode (ie hit “U”) then I must switch to a translate mode(ie “V”) if I want to move/rotate/scale my selection. Does a single mode exist that would allow me, for example, to select an array oof components, move them, deselect them, then select a new array that can be transformed? Or must I get used to the constant mode switching?
I personally mapped my keys to the standard QWER that Maya uses. With sticky keys, you can hold down your Rectangle Select Tool (mine is Q), while holding down, select your components, let go, and you’ll be back in your translate mode.
You can also set your Preferences/Tools/Transform to a lower Move Point Pick Size.
Hope this helps.
