hy,
say i have 5 objects. i select two and i want to invert the selection
and turn primary visibilty off for the other 3.
i tried using the command invertSelection, but that will select the
transform nodes and somehow i can't select the shapeNodes with
listRelatives.
help please
QUOTE(pete1973 @ 07/22/06, 03:19 AM) [snapback]243078[/snapback]
listRelatives.
erm, listRelatives only LISTS it's relatives. I'd suggest using the select command
typically you only actually select transforms. Selecting shape nodes doesn't happen in Maya unless you script it.
