I made a book with a lot of pages. Now i want to select a part faces of each page simultaneously, otherwise i have to repeat this at least a hundred times.
Is there any way to do this?
Thanks in advance,Addepat
are the faces on the same part of each page?
Yes, they are.
well, i just found out i have to selct the whole bunch of pages in Object Selecting mode, then switch to Component mode and the i can select the vertices all together, but no faces untill so far.
select all of the pages and then press F11. (btw F8 - F12 are component keys and can be used pretty handily with control key to convert selections)you should be able to marquee select the faces then.
