Hey, ok this should be dead simple, but I can't work out the syntax.
Basically I want to be able to be able to select a bunch of geometry, cubes, cylinders, etc, then go through a loop randomly instancing one of them each time through.
So far I have...
string $sel[] = ls -sl
for ($i=0; $i<10; $i++)
select $sel[1];
instance;
now this is just going to select a specified object from the selection, what I want is to be able to select a random object of the selection each time it loops through.
Many thanks, Chris
