How do I move selection handle out of the joints?
select the joint, Display->Component Display->Selection Handles.Click on component mode - select the mask that looks like a plus sign. Select the handle, move it where you want it. Go back to object mode and you're all set
[HI, Thank,but i have been doing that...after selecting the bone i go in component mode(f8)..then right click on the plus and pick mask selest it but it selects the whole joint and the whole jint moves rather than just the handle moving...where am i going wrong???help!!!!please
select the joint, open attribute editor, go to Display, enter a number in the X,Y or Z field of "selection handle"
in component mode press on the plus( don't right click) and make sure all the other masks are off...then click on the handle in your view...should do the trick!?
