Semi-corrupted scene-resurrection needed
Hello,
I got this scene of a room, wich constantly gives me the creeps.
First, all works fine, then, in XSI2 I first have to delete a primitive cylinder to make my scene renderable again.
Now, as the first camera moves and animations are supposed to render, a new situation occured: I can only render one frame at a time, the second (and sometimes even the first) crashes.
Recently I still had a rough character merged (but stored externally) into the scene, and when I killed it, any new saved file (scene without char) wouldn
One thing you could try is to export the scene in dotXSI format (both 3.0 and 3.5) and re-import it in XSI. I don’t know why, it sometimes fixes some corrupted elements.
BTW: When you design, model, texture and rig your scenes, do you always only save? What I mean is that it’s good to save under a new name (in my case I increase a number) once every major addition to the scene.
Hope this helps
Salutations - Cheers
Bernard Lebel
