Hi. I made a model that is all one mesh and I have already textured the face. Now I want to do just teh body, then the arms, and so on. The thing is I dont know how to put a texture on just the body without overdoing the face. I also don't know how to make the other uv coordinates go away so I am just working with the body. Can Someone help me out here or lead me to a good plave to learn? Thanks in advance.
To separate UV's simply select the edges that make up the seam, then go edit polys/texture/cut uv's.
To hide portions of the uv map, select the uv's you wanna work on, or just some of them (then rmb in the texture editor/select/select shell) and then rmb in the texture editor...view/view contained faces.
Good luck
