I will try to be a bit more detailed with the problem. The footage we are working with is actually 3 perf 2k image files, cineon 10 bit, with a resolution of 2048X1167.
We have tried numerous experiments with the composition size. We tried importing the 2048X1167 footage into a composite the size of 2048X1556, and the problem still persisted.
What we noticed was that the footage blurs a bit, as well as shifts upward on the y axis.
So in order to replicate the problem I am seeing, I suggest opening a file with 2048X1167 image size, and comparing the original footage with the composite views or nested composite views. Be sure you are viewing the comp in best mode; in preview mode you cannot see a difference.
