is there a way to tell maya, that when i m animating, to set keys in step tangents by default? thx
Sure go to settings and preferences and change default key type, or get one of the myriad of scripts that make mm of this option.
ok
here is another puzzle
how can I create a custom int attribute and make it always key in stepped, while other attributes still animate any other way? similar to the bool attr but with int.
Yury
Thst is a bit tricky yes. What you do is not to issue this but kjey normally and set up a scipt job to set the channels you need whenever keyed AFTEr tehy are set. The problem sith this si that how do you know if the user has set the tangent manually?
