Simple solution to your problem for manual rigging:
1) Create a control object to be used as the pole vector control
2) Align the control object to the "knee" or "elbow" of the IK chain. Align both translation and orientation.
3) Translate the control object along local axis away from the "knee" or "elbow"
As the previous poster suggests, the control and IKRP solver need to be aligned (on the same plane) or you will have a mild shift when the IK effector is created.
Also a good idea to set the joint orientation before applying IK.
