i was wondering how to i should go about setting up a system whereby i can use a script to set off multiple shake files to render sequentially rather than simultaneously.anybody got any good ideas? i am not very technical, so a step-by-step description would be really appreciated.many thanks...
be sure to put a semicolon after each command...for a step-by-step description use the search function ++ christoph ++
sorry,i don't understand...could someone please explain to me how to set up a batch render or render queue system for shake?as i said, i am not technical in any way, so a detailed explanation would be great.thanks...(what is the seach function?)
the search function is the field on the top of this site which says: "Advanced Search or Quick Search: ______ (Go)"
you should use it lot because you'll find useful posts like this one:http://www.highend3d.com/boards/index.php?...hl=batch+render
there's at least 10 more topics about this, so maybe you'll understand why nobody is really interested to write it again.++ christoph ++
Error: Backend Fetch Failure
