Setup and translate on joints
Hi everyone. I have a question about setup and joints chain.
I know it is said that before make IKs, we shall have all translate Y and Z values of the joints (except for the first parent joint) to Zero, and all rotate value to zero as well.
I heard also about the last child of the Joint chain that should have zero to all “joint orient” values.
I tested it, and i have find that :
-When some rotate values are not fixed to zero, the IK moves the joint chain on creation.
-When we freeze transforms rotate values, so all rotates are zero, the IK doesn’t moves the Joint chain, even if they are some translates values in Y and Z on the child Joints.
So my question is : why shall we create Joint chain with Zero translate Y and Z ? Why Zero also on “Joint orient” values of the last child of the Joints chain ?
Thanks you for any answer .
