How can I make an object throw a Shadow while using the cartoon-shader?
I don't think cartoon shader supports shadows
I suggest you to calculate shadows with a shadow render pass and then composite.
Hope this helps
Ste
Toon shader does support shadows, but the current build has a bug. Fixed in an upcoming release.
Matt
Matt LindAnimator / Technical DirectorSoftimage certified instructor: Softimage|3D Softimage|XSIspeye_21@hotmail.com
If you use the toon_paint shader and plug it into the shadow port of the material you'll get shadows. Thanks to Georg for this one
Ivanp.
You can also connect a phong node to shadow port of material and toon in surface. You will obtain shadow...Great
Mmmm.. arealights on toon stuff... mmm... (and even longer rendertimes)
You can also simply disconnect the toon shader from shadow imput.
Lepo
Grande Lepo
Steurba
Ciao Ste
