I want to put a white constant material on a grid. Now I want to see shadows from another object on this constant material. But that doesn
I will do this:copy a file ,one use constand shader,annother use something can be shadowed(i think lermbet is good),and give it a shadow pass.then render them and composite them all in after effect.
hope this will help you
The manual states that the "Constant" shader ignores lighting and only uses the color you specify.
To get shadows you'll need to use a different material shader.
Matt
Matt LindAnimator / Technical DirectorSoftimage certified instructor: Softimage|3D Softimage|XSIspeye_21@hotmail.com
