What is the code in your macro? ie. When you open your macro and it show red, that there is an error, what does the code read in each of your paramaters?
The only reason I ask is because I have run into this and fixed it by editing the code to keep the original expression, but I don't allow it to be editable because it would then no longer work due to the expression.
Send me the code for each parameter when you get a moment and I'll look at it.
