Shake 4 Install On Fedora 4
Hey everyone,
I’m a major linux noob and I need a ton of help installing shake 4 and maya 7 on my fedora 4 64bit machine. I don’t really know how to install the nvidia drivers either for my video card (nvidia quadro 1100). Any help will be appeciated. Thanks.
Randogg
Shake and Maya are 32 bit apps, so stick with the 32 bit install. To install the apps and the drivers simply read the install instructions that come with them, it’s very easy to follow. Once you have tried and have had a problem, then come back and ask about specifics.
Hello, for nvidia driver, here is a complete guide , just follow instructions. and about shake, in FC4 you will probably have a message like this : “cannot restore segment prot after reloc: Permission denied” when launching Shake, because FC4 have a new kernel security extensions from the SELinux project, enabled by defaut. so you have to disable it for Shake’s library folder, like this :
  • Change the default security context for Shake by issuing the command:
    chcon -t texrel\_shlib\_t /usr/nreal/shake-v4.00.0607/lib*.so
or
* Disabling SELinux altogether by setting the line
  SELINUX=disabled
  in your /etc/sysconfig/selinux file.
