Shake Multiplane Maximum Frame!?!?!?!
Hello everyone...i tracked a shot in boujou...995 frames....the track work great...it work in Flame....it work in aftereffect, Xsi and maya as well...only in shake...it loads only the first 720 frames....what's the deal....is this a limitation of the multiplane.......??
thanks
vincentp
Check the duration of the sequence in filein and make sure that the frame padding is done right. and also most important is the target and source frame rate is set right and are same.
