Shake Retiming Issue
hi
i have a 24 fps sequence that have to be composited as old film shot at 16 fps (variable manual speed - old camera) but played at 24. everything should look a bit faster but not by speeding up but rather by doubling some frames here and there. somehow timeX node sucks when it comes to expressions.
is there any method to bypass this issue (timeX not working properly)
thank you
well, timeX has some issues, but it usually worked fine if i took care of it's limitations..
what expression are you putting in?
i also had good luck with using a step function, either in the filein or a timeX
++ chris
