Hi All, first off I am a bit of a noob when it comes to Shake, I'm primarily a 3d guy but I have been tasked to create plugins for Shake. I was curious if anyone has much experience with the Shake SDK, specifically with UI plugins that use modal Dialogs. I have been trying to figure out how to invoke a dialog from a menu, and so far have had no success. At the moment, all I am trying to do is call the modal Dialog example that comes with the sdk. In the example, its called through the notify function from a node. How it is called from the example seems straight forward, but when I try to extract it from the node, and have it as a stand alone function, I can't get it to work. Anyone have any ideas? It seems there is enough examples for the SimpleModal Dialog, but custom modal dialog examples and reference seems to be a bit lack lustrous.
Any help would be truly appreciated.
Greg
