hi, can anyone help me in determining the name of the shape node.
"Create a distance tool" , two locaters are created.
there is a start point and an end point and one distance.
can the name of the start and the end point be overridden or changed.while creating it.
I WANT TO MENTION THIS IN A SCRIPT FOR CALCULATING THR STRETCH FACTOR IN AN IK SETUP. IN MAYA
thanks a lot
please help.
you want to use the distance tool in your script for IK setup stuff?
Don't.
Script it by yourself. You know distance is easy to calculate: d
if you're using it to find the max length of the chain before stretching is taken into affect...try looking at the child joint's translation. Say you setup a chain in the side viewport, with XYZ orientation, then the child joint's x translation is in essence the length of the joint. May be another way to go about it.
