My problem is cloth vibrations, how can i do it ?
in the garment method no vibration, but polygon convert to cloth it did vibrations..how can i solution this problem..
Thanx.
you want to add or decrese vibrations.
to decrease, vibration increase samples! But it might be relatd to your topography.
Thanx for your answer but my problem I don't want vibration, this vibration problem, only made in local vertex.
-you will most likely need to increase the collision surface resolution or the cloth resolution, pretty simple...
Error: Backend Fetch Failure
