Shockwave export (2)
Hey all,
Having a problem with the shockwave export VBS for XSI 1.5.3. In the documentation it says to load the VBS file into the script editor and click run etc and then prompting you for .xsi file to be used. However when I run the script I get an error
" activex component cant create object ""mscomdlg . commondialog""
I tried installing the latest VB runtime files from Microsoft site and reloading the w3d pluggin to no avail.
Does anyone know why this is happening? Fix? etc.
Thanks in advance
RaiThioS
anyone?
You can try to download the Visual Basic Control Creation Edition which contains the MSComDlg.CommonDialog which is located here:
http://download.microsoft.com/msdownload/s...ce/vb5ccein.exe
I hope this helps, it worked for me when I needed that control.
Robert B.
So it IS possible to export animations made in XSI to shockwave?
I hope somebody will post a more detailed explanation about this process..
Cheers!
G
You can check here for the details.
http://www.softimage.com/download/xsi/converters/
There is an FAQ section also.
Hope this helps.
Robert B.
