Silly New Users Questions! 8)
Hello,
I’m just basically going through the initial learning curve of the package, and was wondering a couple of things : -
  1. On page 91 of the fundamentals book it states :-
    1. Click the Property button in the Selection Panel to display the selected object’s property nodes.
I can’t see any Property button, I’m using 1.5 btw?
  1. How can I set my Nurbs diplay smoothness, you know like pressing 1,2 and 3 in Maya?
  2. I ‘WAS’ going to ask why I can’t merge vertices as well, but it looks as though that has been covered.
Cheers in advance.
Steven J. Tubbrit
http://users.tinyworld.co.uk/steven_tubbrit/http://users.tinyworld.co.uk/steven\_tubbrit/
the property button is not there anymore in 1.5, it’s a doc bug You can acces object’s properties via the “selection” button, or the explorer, or enter, ALT+enter,e tc.
I’m not sure, but I beleive nurbs are always smoothed at display in Xsi.
Welcome to XSI
Grand Strateguerre
http://elfstone.3dvf.net/
Hi,
By default all NuRbs objects have the same geometry approximation value : step of 6 as far as i remenber
If you want to modify locally for your object just select it and choose Property > geometry approximation this will add a new local property.
In the property page choose your Display values ( hardware )
you can have different for the render. If you want a shortcut for changing the step value just open the script editor and drag the line that has been logged, modify it as wanted and drag it in a new custom toolbar…you have got now a button on which you can assign a shortcut…
If you want to modify step for everyobject do the same but on the scene property node…
RCR
Http://roger.rosa.free.fr
Hi,
thanks for both replies.
very helpful,
Cheers.
Steve
Take the books you have and throw them away. They are obsolete. There are too many changes in the manual between v 1.0 and 1.5.
So I suggest you consult the HTML documentation instead, which is ‘mostly’ up to date (not incorporating the changes from 1.5 to 1.5.1). I know it’s no fun to go back and forth from XSI to a web browser. You could print parts of it as you advance in the wonderful world of XSI…
flord.
