QUOTE(ceileachair @ 06/02/08, 07:31 AM) [snapback]286555[/snapback]
I'm just getting started in maya particles, and was disappointed to find out that the instancer doesn't allow you to instance lights.
Yes that would defeat the point of calling it a instance, instance reefers to sharing the pointdata, since a light has no point data and in no way lessens the computational cost it would be stupid to kket you do it. Asit is as heavy as having x nonistanced lights.
You can still use particles to drive transforms if you wish what you do use a softbody to connect the data. Thst the optimal way you can offcourse use expression to create them on the fly but i suggest you avoid that and do it only at rendertime (your viewport wont show the lights anyway).
And yes someone had a script for ithis on their homepage, cant remember where tough.
It is however lighter to use final gathering instead.
