i’m trying to produce a classic example of the cup handle. i’m using a nurbs shape for the cross section with a path for the profile, both extrude and loft functions give me completely incorrect results. what am i doing wrong??!!
To make the handle for the cup, you usually would make a profile curve, somewhat near (even snapped) to the path… Look at these images. You can probably just pick up on the sequence.
Here I’ve drawn the path curve in the side view and just lined it up on the axis’ accordingly.
Here I’ve drawn the profile curve and snapped it to end of the path curve I drew the step before.
Select the profile curve first, and then the path curve. Click the extrude button (tool, whatever). The surface generated might not line up perfect because of some minor default flaws..so..press Control-A (attribute editor) to control the extrude options.
… help? vivekr@ntplx.net
