Solutions for no render menu bugs for mental ray
This is a solution that has worked for me for the past post on the mental ray bugs.
after mental ray is intalled correctly I found that somehow it messes with ur maya user preferences which I believe to have caused the problem and causing render menu not to appear.
Solution is create a new administrator account in ur computer ( that is what I do in Win XP)
After that load maya, initiate the mental ray plugin in the plugin manager.
It should run fine now and u will be able to render again but only from ur new account that u just created.
However if u insist on using ur old account, u can do it by copying all the files under ur new administrator account’s C:Documents and SettingsuserMy Documentsmaya4.5( including all files under ur folders and subfolders to the same dir of ur previous / account that did not work. Make sure that u copy and paste everything to ur old account and make it really 100 % identical to the files on ur new acc. after that u can delete the new acc u just created
I have done this many times since I also had a problem with installing shave and a haircut but after the steps I told u everything works fine
another one - not as intrusive - open render view (Window->Rendering Editors->Render view) - Options->Render using->…
someone posted that setting mental ray as the default renderer in your preferences will solve the problem permanently
